May 6, 2016 2:15 PM UTC
Multiple sessions of Creo 3.0
With Creo 2.0 it was possible to have two separate sessions open simultaneously tied to two different windchill workspaces. This functionality is not working within Creo 3.0. When the second session is switched to the second workspace it erases everything in memory of session #1.
Did they change this functionality to where you have to use the WF_ROOT and set your cache to different locations now? Yes I understand the reasoning behind this if they did, I was just curious.
