DomenicLaritz
Nov 5, 2015 8:44 PM UTC
Notepad++ User Defined Language files for Creo Parametric and Pro/ENGINEER
The ZIP archive contains Notepad++ UDL files for config.pro and drawing setup (dtl) options.
I've created them for following CAD versions:
  • WF4 (= Pro/E Wildfire 4)
  • CEP5 (= Creo Elements/Pro 5, formerly Pro/E Wildfire 5)
  • CP2 (= Creo Parametric 2)
  • CP3 (= Creo Parametric 3)
  • CP4 (= Creo Parametric 4)
Basis for the options were the lists of Olaf Corten (thanks for them) http://proesite.com/UTIL/view_config.html and http://proesite.com/UTIL/view_setup.html.
General config.pro options get shown dark blue and bold.
Hidden config.pro options get shown in a lighter blue, bold and italic.
Comments get shown brown and can be folded, if they consist of several lines.
Drawing setup (dtl) options alse get shown dark blue and bold.
To add a UDL file to Notepad++, choose "Language" and then "Define your language" in the menu.
In the dialog which is opened then, choose the button "Import" and then the appropriate XML file.
https://github.com/DonChunior/Creo-Configuration-Files
DomenicLaritz
Jan 12, 2021 8:26 AM UTC
I've released the new version 6.2.1 of the Notepad++ UDL files on GitHub:
  • Olaf Corten's config.pro settings lists from Creo 4.0, 5.0, 6.0 and 7.0 contained some mistakes, according to his own information, so he had to regenerate them.
    These new settings lists have been adopted.
Thanks to @ocorten-2 for providing the lists with the settings on his website https://creosite.com/.
DomenicLaritz
Jan 22, 2021 9:47 AM UTC
I've released the new version 6.3.0 of the Notepad++ UDL files on GitHub:
  • New UDL file for ModelCHECK based on Creo Parametric 7.0.2.0 documentation.
  • In the ModelCHECK UDL file of Creo Parametric 4.0, the config_init.mc setting FORCE_UPDATE_MC_PARAMS_ALL was missing and has been added.
DomenicLaritz
Apr 21, 2021 8:21 AM UTC
I've released the new version 6.4.0 of the Notepad++ UDL files on GitHub:
  • Updated UDL files for Creo Parametric 6.0.6.0 and Creo Parametric 7.0.3.0.
DomenicLaritz
May 4, 2021 12:18 PM UTC
I've released the new version 7.0.0 of the Notepad++ UDL files on GitHub:
  • Added UDL files for Creo Parametric 8.0.0.0.
  • Updated UDL files for Creo Parametric 4.0 M150.
DomenicLaritz
Nov 9, 2021 2:42 PM UTC
I've released the new version 7.1.0 of the Notepad++ UDL files on GitHub:
  • Updated UDL files for Creo Parametric 7.0.6.0 and Creo Parametric 8.0.2.0.
  • Added some missing ModelCHECK settings from Creo Parametric 7.0.6.0 and removed an invalid one.
DomenicLaritz
Feb 3, 2022 2:54 PM UTC
I've released the new version 7.2.0 of the Notepad++ UDL files on GitHub:
  • Updated UDL files for Creo Parametric 7.0.7.0 and Creo Parametric 8.0.3.0.
DomenicLaritz
May 17, 2022 12:43 PM UTC
I've released the new version 8.0.0 of the Notepad++ UDL files on GitHub:
  • Added UDL files for Creo Parametric 9.0.0.0.
  • Updated UDL files for Creo Parametric 7.0.8.0 and Creo Parametric 8.0.4.0.
DomenicLaritz
Nov 14, 2022 10:10 AM UTC
I've released the new version 8.1.0 of the Notepad++ UDL files on GitHub:
  • Updated UDL files for Creo Parametric 7.0.10.0, Creo Parametric 8.0.6.0 and Creo Parametric 9.0.2.0.
  • Drawing detail options now marked as hidden in Olaf Corten's lists are displayed in the same style as hidden config.pro settings.
DomenicLaritz
May 11, 2023 11:51 AM UTC
I've released the new version 9.0.0 of the Notepad++ UDL files on GitHub:
  • Added UDL files for Creo Parametric 10.0.0.0.
  • Updated UDL files for Creo Parametric 7.0.11.0, Creo Parametric 8.0.8.0 and Creo Parametric 9.0.4.0.
  • Possibility to group config.pro settings using the syntax ! ===== for opening and ! ----- for closing the group (thanks to Flo-R1der).
DomenicLaritz
Nov 22, 2023 11:17 AM UTC
I've released the new version 9.2.0 of the Notepad++ UDL files on GitHub:
  • Updated UDL files for Creo Parametric 7.0.12.0, Creo Parametric 8.0.9.0, Creo Parametric 9.0.6.0 and Creo Parametric 10.0.2.0.
