DomenicLaritz
Nov 5, 2015 8:44 PM UTC
Notepad++ User Defined Language files for Creo Parametric and Pro/ENGINEER
The ZIP archive contains Notepad++ UDL files for config.pro and drawing setup (dtl) options.
I've created them for following CAD versions:
  • WF4 (= Pro/E Wildfire 4)
  • CEP5 (= Creo Elements/Pro 5, formerly Pro/E Wildfire 5)
  • CP2 (= Creo Parametric 2)
  • CP3 (= Creo Parametric 3)
  • CP4 (= Creo Parametric 4)
Basis for the options were the lists of Olaf Corten (thanks for them) http://proesite.com/UTIL/view_config.html and http://proesite.com/UTIL/view_setup.html.
General config.pro options get shown dark blue and bold.
Hidden config.pro options get shown in a lighter blue, bold and italic.
Comments get shown brown and can be folded, if they consist of several lines.
Drawing setup (dtl) options alse get shown dark blue and bold.
To add a UDL file to Notepad++, choose "Language" and then "Define your language" in the menu.
In the dialog which is opened then, choose the button "Import" and then the appropriate XML file.
https://github.com/DonChunior/Creo-Configuration-Files
DomenicLaritz
May 4, 2018 7:11 PM UTC
I've released a new version of the UDL files at GitHub.
The UDL files for Creo5 have been added.
DomenicLaritz
Jun 15, 2018 7:28 AM UTC
I've released the new version 3.1.0 of the Notepad++ UDL files on GitHub:
  • Updated UDL files for Creo Parametric 2.0 M250, Creo Parametric 3.0 M170, Creo Parametric 4.0 M050 and Creo Parametric 5.0.0.0.
  • Removed some invalid settings (although they are documented).
DomenicLaritz
Aug 5, 2019 12:14 PM UTC
I've released the new version 4.0.0 of the Notepad++ UDL files on GitHub:
  • Added UDL files for Creo Parametric 6.0.1.0.
  • Updated UDL files for Creo Parametric 4.0 M090 and Creo Parametric 5.0.4.0.
Aug 8, 2019 12:19 PM UTC
Hi Domenic,
I tried importing those CP4 files but both failed to import.
DomenicLaritz
Aug 8, 2019 1:01 PM UTC
I've just re-tested it myself to be on the safe side, but importing the UDL files works fine for me (I'm currently using version 7.6.4 of Notepad++).
Here is my procedure:
  1. Downloading the zip archive (not tar.gz) from https://github.com/DonChunior/Creo-Configuration-Files/releases/latest.
  2. Extracting the zip archive.
  3. Choosing "Language > Define your language" in Notepad++.
  4. Clicking the button "Import".
  5. Choosing the file config_Creo4.xml from the extracted archive and clicking "Open".
  6. A message box saying "Import successful" pops up and I click the button "OK".
  7. Closing the dialog "User-Defined" by clicking on the "X" in the top-right corner.
  8. After a restart of Notepad++ in the menu "Language" the entry "config Creo4" is listed.
Where exactly does it fail for you?
DomenicLaritz
Sep 18, 2019 12:51 PM UTC
I've released the new version 5.0.0 of the Notepad++ UDL files on GitHub:
  • Added UDL file for ModelCHECK based on Creo Parametric 4.0 M100 documentation.
DomenicLaritz
Apr 10, 2020 7:57 PM UTC
I've released the new version 5.1.0 of the Notepad++ UDL files on GitHub:
  • Updated UDL files for Creo Parametric 4.0 M120, Creo Parametric 5.0.5.0 and Creo Parametric 6.0.4.0.
DomenicLaritz
Apr 17, 2020 6:47 AM UTC
I've released the new version 6.0.0 of the Notepad++ UDL files on GitHub:
  • Added UDL files for Creo Parametric 7.0.0.0.
Thanks to @ocorten-2 for providing the lists with the settings on his website https://creosite.com/.
2-Explorer
Jun 17, 2020 12:37 PM UTC
Thanks a lot Domenic for sharing your work
Apr 17, 2020 12:36 PM UTC
Bless you, Domenic !!
DomenicLaritz
Aug 21, 2020 8:26 AM UTC
I've released the new version 6.1.0 of the Notepad++ UDL files on GitHub:
  • Updated UDL files for Creo Parametric 4.0 M130, Creo Parametric 5.0.6.0, Creo Parametric 6.0.5.0 and Creo Parametric 7.0.1.0.
DomenicLaritz
Aug 21, 2020 9:45 AM UTC
I've released the new version 6.1.1 of the Notepad++ UDL files on GitHub:
  • Fixed XML issues that caused some UDL files to not import correctly.
Aug 21, 2020 12:32 PM UTC
Domenic,
Notepad++ for Creo config files has been a HUGE help in doing my job...thanks...Barry
DomenicLaritz
Aug 24, 2020 7:07 AM UTC
Hello Barry,
thanks for your appreciation. It is encouraging to hear when others are also helped with the UDF files.
Best regards,
Domenic
DomenicLaritz
Dec 10, 2020 8:46 AM UTC
I've released the new version 6.2.0 of the Notepad++ UDL files on GitHub:
  • Updated UDL files for Creo Parametric 4.0 M140, Creo Parametric 6.0.5.1 and Creo Parametric 7.0.2.0.
Dec 10, 2020 9:40 PM UTC
I tried importing the Creo 7 config UDL and it wouldn't import.
I imported the previous Creo 7 config UDL and it did import.
DomenicLaritz
Dec 11, 2020 7:23 AM UTC
I can't find any problem, it works fine for me.
I usually update the UDL files as follows:
In Notepad++ open the UDL dialog ("Language > User Defined Language > Define your language").
Set the UDLs to be replaced in the drop-down menu and remove them.
Close the UDL dialog and then restart Notepad++.
Then install the UDLs according to the instructions (https://github.com/DonChunior/Creo-Configuration-Files/blob/master/README.md) and restart Notepad++ again.
