Jun 21, 2016 5:00 AM UTC
Open new version file
hi,
I am currently using Creo parametric v2.0 but need to open a newer version Creo data (.prt and .asm).
1) How can I do that?
2) How to upgrade to newer version?
3) Do I need to purchase new license in order to upgrade?
Thank you!
Jun 21, 2016 1:04 PM UTC
Assuming that you have an active maintenance contract, you can download and install Creo 3.  You'll find it here (you'll need your company's maintenance info to access it):
https://support.ptc.com/appserver/cs/software_update/swupdate.jsp
If you do not have an active maintenance contract, you will have to renew your maintenance with your VAR, as Martin said.
If you simply want to open the Creo 3 files in Creo 2, you can check out the GCRI plugin info here:
http://support.ptc.com/products/granite/gcri/free-download.htm
GCRI gives you a limited ability to work with newer version files.  Opening is no problem as is, I think, adding features.  Editing the existing features is not possible, though.
Jun 21, 2016 8:23 AM UTC
contact your Value Added Reseller.
MH
wneo1-VisitorAuthor
Jun 27, 2016 2:48 AM UTC
Thanks guys for all your help & comments!
Mahesh_Sharma
22-Sapphire I
Jun 29, 2016 7:58 PM UTC
Wilson,
Could you please mark reply from Doug on this post as correct answer?
