Sep 29, 2015 2:02 PM UTC
Order Independent Transparency and memory issues
Recently updated to M090 of Creo 2.0 and discovered that order independent transparency works with NVidia cards. This is awesome - performance is more than 10x what it was. Problem now is memory issues. Seemingly random crashes with the message "An application has requested more GPU memory than is available on the system".
Is this a known issue that is resolved in a later spin or anyone have any fixes? I'm using a GTX 570 with 1280mb of GDDR5.
KenFarley
Sep 29, 2015 5:11 PM UTC
General question. Why update to M090 when the current release is M180? I don't know if there are any particular enhancements that relate to graphics, but that is a pretty old release. I seem to recall having some odd behavior around the time those versions were out...
Sep 29, 2015 6:13 PM UTC
Kenneth,
  Yeah....M090 is the last spin we got before maintenance expired
StephenW
Sep 29, 2015 5:18 PM UTC
I turned off order independent transparency shortly after enabling it. Seemed to cause way too many crashes. Haven't tried it since.
Sep 29, 2015 6:15 PM UTC
Stephen,
  I can't ignore the performance gains I've seen with OIT. Makes working in a large transparent assembly absolutely seemless and smooth. I need to figure this out.
Sep 30, 2015 8:28 AM UTC
Where is the option set - with Creo, or within the Nvidia Control Panel?
Sep 29, 2015 5:35 PM UTC
OIT needs a graphics card that supports Open GL 4+.  I believe the GTX is a gaming card, and you need a Quadro Series card to get the Open GL.
Sep 29, 2015 6:33 PM UTC
Bill,
  Yes, it is a gaming card. I've always used gaming cards, as they are 1/4 the price of the comparable Quadro card. Have had several Quadro cards over the last 17 years and ran benchmarks against their gaming equivalents. Have really never seen the performance difference to justify the major cost difference - possibly until now. Honestly, the performance of  this card is still awesome - except in transparent mode. That is until OIT option came along....Now it's awesome all around - until it crashes a few times a day. I'm currently using it, but I've had to increased my "save" frequency. Can't predict what will cause or when it will go out of memory. This is the most frustrating part.
This is why I'm trying to see if it's an amount of memory issue, GTX vs.Quadro driver/architecture issue, or a newer spin of Creo issue.
Sep 29, 2015 11:52 PM UTC
From what I have seen, of those 3 things I am leaning towards amount of memory. I run a GTX card, but running M180 currently, but I have run M90 and I don't remember an OIT issue. I also don't remember which build added OIT either.
