Jun 5, 2014 3:27 PM UTC
persistent hidden layers, assemblies and components
Something has changed. I have no idea what. Hope y'all can help.
I try to live by the admonition :"save early and save often"
When I hide a layer or component or assembly, it remains hidden when I re-open the file. This used to not be the case -
I swear, I have NEVER saved layer states. Really. NEVER, EVER.
I renamed my config.pro file (old_config.pro) so the stock config.pro file is loaded (I hope).
The behavior persists.
Any ideas? What have I done?
Creo 2.0 M010
Thanks!
Jun 25, 2014 7:01 PM UTC
Resolution was (you're gonna love this):
1.burn the config.pro files
that didn't work - hidden models were still persistently and perversely hidden
2. re-install creo (what fun! only took the whole afternoon! another day ***poof!***)
This seemed to chase the goblilns away. Or maybe it was the phase of the moon. Or sunspots.
Anyway, it's back to what passes for normal now.
2-Explorer
Jun 5, 2014 3:49 PM UTC
It depends. How long have you been using PTC CAD?
PTC changed the behavior at least as far back as Wildfire. Before that Hide was a transient, unsaveable change. Then PTC merged it into layer management and made the Hidden layer permanently, well, Hidden. This meant that no Save Layer Status was required, but I think it stinks, as there is some benefit to an unsaveable transient visibility status. Like not ever having to worry about making an accidently state change that affects drawings and upper level assemblies.
I guess create a mapkey that performs Unhide All and then Saves.
Jun 5, 2014 8:49 PM UTC
Six months. And if I can't fix this, maybe not much more .
How can I save this mess so that when I (or someone else) opens it, the models aren't hidden?
Jun 5, 2014 9:35 PM UTC
You can always delete those layers and unhide everything you expect to see. Then save the layer status.
Jun 5, 2014 4:59 PM UTC
I for one have resorted to always start with an "empty" part or assembly. No auto-layers and frilly behavior.
Things do still hide on their own when I use a sketch for an extrude, for instance; or I create a datum on the fly (within a feature) and it then hides itself once the feature is complete.
Layer states that I specifically change always reverts if I forget to save the status.
Jun 6, 2014 4:59 AM UTC
Jim,
Creo 2.0 M010 is VERY OLD maintenance release and it is "unfinished". I suggest you to move forward and use more recent maintenance release. Current maintenance release is M110.
Martin Hanak
Jun 6, 2014 7:15 PM UTC
Have you tried right clicking on "Layers"and going to "Reset Status", just to make sure it hasn't been saved by some default magic that PTC has invented?
Jun 20, 2014 9:22 PM UTC
Hi Jim,
Let us know if this is still an issue or if you resolved it. Also please mark one of the posts as "Correct Answer" if applicable. Otherwise, mark your own response as correct if you figured it out on your own.
If this is still an issue we should confirm it is something being done by your machine or if another user is making the change and saving the status.
  1. Open a model
  2. Hide a layer
  3. Save and Close the model
  4. Erase Not Displayed
  5. Reopen the model
If Hidden status upon retrieval, there probably something in your config.pro. Perhaps your administrator changed the start-up script and adds a config option
  1. Click File > Options > Configuration Editor
  2. In the top right of this dialog box, click Display Filters and confirm "Current Session" is showing.
  3. In the bottom right of this same dialog box, click Export per Current Filter
  4. Save this file to your desktop and open it in a text editor
  5. Cut and paste the content of this file here as a respone in this discussion
ptc-54934771-VisitorAuthorAnswer
Jun 25, 2014 7:26 PM UTC
At least you didn't have to reformat your drive
Thanks for posting the solution!
