Sep 8, 2013 5:32 AM UTC
Questions about .prt files.
I am curious. Why is it that when you save with creo, it saves it as .prt.1, and .prt.2 if there's already one of that type? Wouldn't it be easier to prompt for overwrite like every other program than to associate every number .prt.1, .prt.2, .prt.3, etc. to creo in windows? And with the same Idea, why is it that before I associate .prt.x with creo, windows shows me a preview of the object as the object's icon, but when I associate it with creo, it just show's a program-style icon? and is there any way to get that back without un-associating creo with that filetype? And can I prevent the .prt.x? Can I have creo automatically associate all .prt.x files up to a certain number with creo in windows? I'm using Win8, if that's relevant.
Sep 8, 2013 5:56 AM UTC
The "versions" is a means to have backup files. If something gets corrupt, or you change your mind about the direction your going, you can recover a previous version. Its been part of Pro|E since a long time ago.
Windooze... doesn't like these type of extensions. I don't know how you can wholesale tie the lot to Creo... I suspect you can't. Besides, Creo likes to have a specific start up folder so you can open the right configuration file when Creo starts. Have you tried "drag and drop"? Works for me!
Oh, and there are two ways to avoid the "duplication":
1. configure the system to recognize the purge command in the DOS shell (YES, DOS!)
2. backup the file in a separate folder and all will begin with .1 again.
Sep 8, 2013 7:24 AM UTC
Well, it's doable, but not very straightforward. As I explained here: Re: Creo Won't Open Files from directory you can use command line to batch assign specific program to open specific file extension. In theory (because that's the part I've never done myself) you should be able to write a loop in batch file/command line to assing specific ftype to every file extension from .1 to .999 (that's the max Windows can handle, AFAIK).
Sep 9, 2013 6:59 AM UTC
It is easy to delete old version of creo files. There is different ways you can do it:
- From Creo on current file
http://www.ptc.com/cs/help/creo_hc/creo20_hc/index.jspx?
- Use purge from commandline on all files in a folder. You can use this for scripting.
https://www.ptc.com/appserver/cs/view/solution.jsp?n=CS34721
- Use a purge tool that will add a menu RMB in windows explorer
There are tools you can download for free.
ex:
http://www.proesite.com/
- Utlities
- Creo Purge
