Nov 30, 2015 2:17 PM UTC
saving problem
Hi
how to save the previous session in creo 3.0.the school we Creo 2.0 and I do not want to open the files you do at home . I got home Creo 3.0
Dec 1, 2015 1:54 PM UTC
As Ben said, there is no saving as for older versions, however Creo 2 should be able to open Creo 3 files using GCRI.  The instructions for use are here:
https://support.ptc.com/appserver/cs/view/solution.jsp?n=CS34964
If you don't have access to that link, you need to copy readnewermodels.dll file from the Creo 3 install here:
<Creo load point>\<datecode>\Common Files\<machine_type>\gcri
Paste the readnewermodels.dll file into your Creo 2 install here:
<Creo load point>\common files\<datecodes>\<machine_type>\obj\
I assume that will work for the student version like it does for the commercial.
Keep in mind, however, that you will not get the feature tree in Creo 2, only the geometry.
Nov 30, 2015 3:06 PM UTC
There is no option to save Creo 3 files in a format that Creo 2 can open.
Creo 3 can open older, Creo 2, files.
