Jan 29, 2010 7:42 PM UTC
stupid friday question
I can't believe that I've been a full-time pro/e user for nearly 10 years
and never thought of this before, but is there a keyboard shortcut for
toggling through pro/e windows (equivalent to Alt-Tab, but that works only
in pro/e windows)
Or a mapkey? Or something?
Thanks.
Lyle Beidler
MGS Inc
178 Muddy Creek Church Rd
Denver PA 17517
717-336-7528
Fax 717-336-0514
<">mailto:-> -
<">http://www.mgsincorporated.com>
    StephenW
    Feb 1, 2010 1:37 PM UTC
    Along the same lines, sort of, is using ALT-TAB to get to the window you want and then using CTRL-A to activate it. You're already using the keyboard in that area.
    Feb 1, 2010 2:03 PM UTC
    Brian,
    I am using Windows7 and Pro/E. Look at attached file. Of coures, I am using Ctrl+A for actiavting Pro/E window.
    Best regards
    Radovan
    Feb 1, 2010 2:40 PM UTC
    I am using windows 2000 and wildfire 2 (yes I'm part of the upgrade cycle microsoft has been talking about)
    Since switching to a wide screen flat monitor, I have moved my task bar to the right hand edge of the desktop. Over there it is easily accessable and not overlapping pro/e, I find it quicker to move my mouse to the right and click on the icon that represents the window I want which will "pop it up". With this method, you need to <alt> to make the current window active. This works for me, until I have too many windows open and I have started other applications while working - that puts their icon in the nest of pro/e icons. It's either that or the "window" pull down which when used automatically activates the window selected.
    Stupid question Monday follow up...."what advantage would the window pop up have?"
    Feb 1, 2010 2:46 PM UTC
    Radovan,
    It appears you are clicking twice to get the window to change, and then doing CTRL+A to make the window active? ...or am I missing something?
    With the List of Current Windows, I get from one windowto another in one click, and that click also makes the window active.
    Feb 1, 2010 8:14 PM UTC
    ALT-TAB followed by CTRL-A will switch windows and then activate the one you settle on. No, it's not as nice as the CTRL-TAB you can use in some apps, but it's better than nothing.
    CGB
    <u>
    </u>
    Feb 2, 2010 12:09 AM UTC
    And Alt-Shift-Tab will switch windows backwards through the list...
    Mike Foster
