Sep 13, 2013 12:06 PM UTC
Switching of restructuring via drag&drop
Hi there,
I am looking for a possibility to switch off the drag&drop mode in creo 2.0 that allows the user to bust up the structure of an assembly.
For us, this feature is not only useless (because of the pdm system in the back) but dangerous as you can do it undeliberately besides
the obligatory crash of creo that comes along with it.
I've already checked the 296 pages of the config-options.pdf but no such luck.
TIA,
Andreas
2-Explorer
Sep 13, 2013 2:54 PM UTC
As far as I know, there is no possibility to disallow the drag & drop functionality.
I found an answer from Product Line Management to a similar request for Creo Parametric 2.0, which had been answered as: "This would be an enhancement" (as usual, without commitment to add the enhancement to a specific version)
Of course this request only stated "Drag and Drop behaviour for restructuring asm components is dangerous as it gives no warning to user if it is dragged accidently and even doesn’t show any status in model tree to identify restructured models."
It seems without any dramatic effects documented (like crashes, wrong geometry, inability to check in/out, etc...) the pure idea that a user might not be aware of what he had been doing, was not frightening enough to take immediate measures.
According to a colleague, models restructured in older releases in fact have been a pain when trying to check them in into Windchill PDMLink, but he mentioned that it should no longer be an issue with Creo Parametric 2.0.
The only report about an exit during restructuring I found, was due to a data corruption in the assembly - so it could have happened with other actions as well and was not specific to Restructure.
But if there is any reproducible scenario of restructure causing mischief, it should be reported to PTC Technical Support.
Dale_Rosema
Sep 13, 2013 3:06 PM UTC
I didn't get any comments back on this thread:
http://communities.ptc.com/message/191900#191900
I was searching to see because I thought I had made a product suggestion.
Thanks, Dale
Jun 29, 2015 9:03 AM UTC
No option right now.
I have just voted for this functionality to be added.
Stop Model Tree Reorder Becoming a Restructure - PTC Community
