Oct 17, 2017 9:17 AM UTC
Adding hyperlinks to text field via im createissue in Windows command line interface
I would like to add a hyperlink to a text field (e.g.: summary) when using im – command „createissue“ in the Windows command line interface (cmd.exe). Unfortunately PTC Integrity CLI Reference for Integrity 10.8 stated at the end of this message is not really helpful to fix it. It’s also difficult to deal with the information stated in the “Note” of the explanation for the option “--richContentField=value” related to the Windows command line interface (cmd.exe).
It’s possible for me to create a hyperlink via im – command “editissue” as stated in the following example:
im editissue --user=<user id> --hostname=<hostname> --richContentField=Description="<!-- MKS HTML --><a href=<hostname, etc.>/im/viewissue?selection=2418>Link_Example</a>" 2418
Could you please provide reproducible examples for adding hyperlink via “im createissue” to a text field, for example field “Summary” or “Comment”,etc.. It would be also great to get more information, which option to use for adding hyperlink to text fields. Is “--richContentField” the only option to add hyperlinks ?
Best Regards
Stephan Klemm
specifies a rich content field and its value for the new issue, where value is of the form "richcontentfieldname=fieldValue".
To specify a link to an item by ID: <a href="mks:///item?itemid=ID">DisplayText</a>
For example: <a href="mks:///item?itemid=4547">Part Requirement</a>
To specify a link to an item by ID and label: <a href="mks:///item?itemid=ID&label=LABEL">DisplayText</a>
For example: <a href="mks:///item?itemid=4547&label=EDF-343">Part Requirement, Label EDF-343</a>
To specify a link to an item by ID and revision: <a href="mks:///item?itemid=ID&revision=REVISION">DisplayText</a>
For example: <a href="mks:///item?itemid=4547&revision=1.2">Part Requirement, Revision 1.2</a>
To specify a link to an item by ID and date: <a href="mks:///item?itemid=ID&asof=DATETIME">DisplayText</a> where date is in the format for your locale; such as US date formats "mm/dd/yy", "mm/dd/yyyy", or "mmm d, yyyy" with the time "h:mm:ss a".
For example: <a href="mks:///item?itemid=4547&asof=03/25/2012 12:04:00 AM">Part Requirement, March 25, 2012 12:04am</a>
Note: In the korn shell command line interface, HTML tags must be surrounded by quotes, for example, "<b>Feature Overview</b>". In the Windows command line interface (cmd.exe), the ^ escape character must precede the < and > characters in HTML tags, for example, ^<b^>Feature Overview^</b^> . You may need to escape nested " characters, for example, --richContentField=Description="<a href=\"mks:///item?itemid=4547\">Part Requirement</a>".
Oct 18, 2017 11:46 PM UTC
Hello @sklemm,
Here's an example that worked for me:
$ im createissue --user=kli --hostname=MyHost --port=16000 --type=KLTTest_Widget --richContentField="KLT1_Rich Text=<!-- MKS HTML -->This is rich text.</p><p><a href="https://www.ptc.com^"^>PTC^</a^>^</p^>"
Creating KLTTest_Widget ...
Editing fields ...
Submitting ...
Created KLTTest_Widget 1016
Which created this item for me:
$ im viewissue --hostname=mlizak0l --port=16000 --user=kla --password=mglizak --showrichcontent 1016
Minor Version ID:
Major Version ID:
Live Item ID: 1016
Bookmarks:
Type: KLTTest_Widget
State: KLT1_Active
Modified By: kli
Created By: kli
Modified Date: Oct 18, 2017 7:33:54 PM
Created Date: Oct 18, 2017 7:33:54 PM
KLT1_Attachments:
KLT1_Cost:
KLT1_Description:
KLT1_SKU:
KLT1_Rich Text: <!-- MKS HTML -->This is rich text.<p><a href="https://www.ptc.com">PTC</a></p>
KLT_header_description:
At first glance, this looks inconsistent, because some characters had to be escaped, and others did not.  I think you can get away with not escaping everything between double-quotes (and "escaping" them between the double quotes actually causes problems or at least extra carrot symbols), but after the second double-quote, you must escape them.  Escaping the double-quotes themselves just seemed to create extra double-quotes.
I think the idea was that in Windows, every <, >, and " in the rich text field has to be immediately pre-ceded by a carrot (^), or it's going to be interpreted by the command line (as an input redirect, output redirect, and the end of your quoted string, respectively).  Obviously, that's not completely true in practice.
You can see what's possible by looking at existing output, for instance with the command
im viewissue --user=<user id> --hostname=<hostname> <issueID>
This will show the rich text formatting, so that you can imitate it.
For instance:
<b> == bolding
<i> == italics
An item link would use mks:///item?itemid=123 instead of an a tag.  Note that unlike an href value, the itemid doesn't seem to require quotes.
Re; example field "Summary" or "Comment":  That depends on the field definitions of those fields.  If they are not rich text fields, you're not going to be able to insert hyperlinks no matter what you do.  If they are hyperlinks, you could use the same method as above, substituting the text after the first --richContentField string with the name of your field.  E.g. --richContentField=Summary="<!-- MKS HTML -->...
I hope that helps.
-Kael
sklemm1-VisitorAuthor
Oct 19, 2017 3:34 PM UTC
thanks a lot for providing the example. I've tested it and I confim it's working for me as well,
the item is created in the system.
Unfortunately there's still one remaining issue:
The item shall not be created straightaway automatically. My goal is to prepare the item only without registration and ID in the system. The Integrity user shall manally verify the mandatory attribute values of the prepared item first and store the item after this verification by pressing button "Apply" manually. Only now the new item shall get the ID and shall be created in the system. For this reason I've added the option "-- gui" at the end. Sadly the option is ignored when running "im createissue". It must have something to do with the parameters at the end of the option "--richContentField". Any idea what need to be changed to get the result as expected ?
Best Regards
Stephan Klemm
Oct 19, 2017 4:11 PM UTC
Hello again,
I fixed the issue with the "-- gui" option. It's working when placing the "-- gui" in front of the  option "--richContentField".
But I've recognized another one related the hyperlink:
If I'm replacing your hyperlink by an internal Integrity-Link (http://...) the link is not included anymore.
Should your example work with internal Integrity-Links starting with http:// as well or do I have to change
something to get it working ?
Best regards
Stephan Klemm
