Gateway Export (to Word) works fine, but can't retrieve text field on trace Requirement item
The Gateway Export (to Word) of a Test Protocol document with traced Requirement(s) for each of the Test Cases, through the "Verifes" trace relationship, works fine. It displays the Requirement item numbers, but when I attempt to retrieve a text field (DOORSID; set when imported from DOORS), I am unable to do so.
a) If I add "include-related="true"" for the "Verifies" field, will I be able to retrieve it?
b) Can I use XPath (XML Path) to retrieve the DOORSID?
c) Is there a way to view the "intermediary" XML file before Export to Word, to help troubleshoot the issue?
Balu
Balu,
Unfortunately, it is not possible to refer to data of related items. Please vote for my idea and read explanation as well as further details through referenced articles. You will also find information about provided solution by PTC services.
Regarding your questions:
No, it is not possible, it will only recursively retrieve data of linked objects, but Gateway will never export anything of it ("Flattening tree structure..."). PTC Support told me that attribute "include-related" was introduced for some other integration - their answer has not been more specific.
I don't think that it is possible though I have not tried. I would be really interested in such a solution.
This would be great, however, I don't think that it is stored somewhere, I think it only exists in memory. One possible solution would be to attach a Java remote debugger to Gateway, though this is rather unpromising without source code.
Best regards, Richard.
BaluS1-VisitorAuthor
Thank you, Richard. I did try the XPath, but only field names and counts worked. Nothing was returned when I tried to get field values on the trace item.
