How can get list of files and their revisions with condition/filter =Out of Sync Members.
Basically it is easy to get the list of files Out of Sync Members using the filer in the IMS client + check box "Hide empty sandboxes"
I wonder if I can reproduce this filter using SI CLI, so far I tried with
si viewsanbox
but this command lists all files in the selected folder or project. I would like to have only those with the filter mentioned above.
Thanks.
    kthiererAnswer
    si print seems to use si rlog internally
    Unfortunatly when you try  to configure the output of si print you might fall into the trap
    that it behaves like the si rlog command which by default outputs all revisions.
    So then it is better to use the more complicated si rlog directly.
    You might use the following as template to achieve what you want:
    si rlog --recurse --revision=:member --filter=changed:sync --format="MN:\"\{membername}\" \t MR:{memberrev} \t WR:{workingrev}\n" --noHeaderFormat --noTrailerFormat
    The output here looks like
    MN:"release\README.txt"      MR:1.1      WR:1.1 (The fields are also separated by TABs)
    Note that WR:... may be empty if there is no working file or the revision is unknown in your sandbox.
    The main trick to prevent si rlog from ouputtting multiple lines for a certain member (one for each revision)
    is to use the option --revision=:member
    Extraxt from the CLI Reference for Configuration Management
    --format options use the same values as --fields, but similar to a JAVA MessageFormat string (that is, it requires { } to surround
    each field). The --fields option automatically adds a newline on the end, but you must supply the newline for formats with a \n
    Regards
      Jürgen
    Hi Jorge Guzman,
    Try si viewsandbox --filtersubs.  The --filtersubs argument hides empty projects on my system.  That argument should also work with si viewproject.
    Reference:  si viewsandbox
    Kael
    Edits:
    2016-10-07EDT1108: Added Reference link to si viewsandbox
    If you're just out for the location of the files files and dont need subproject/subsandbox info at all
    you could also have a more compact view and try
    si print --recurse --filter=changed:sync
    For a better parseable format that also adresses whitespace in filenames its a little more complicated:
    si rlog--recurse --revision=:member --filter=changed:sync --format="\"\{membername}\" \t {memberrev}\n" --noHeaderFormat --noTrailerFormat
         Jürgen
    jguzman1-VisitorAuthor
    Hello Klaus,
    I tried the si print and it works partially. For my sandbox the cmd
    returns all out-of-sync files in the project. This is exactly want I wanted as filter. The results looks like this:
        project_folder\myFile.c 1.2 archive
    Where 1.2 is the member revision. I been trying to see if the output of the command also prints the working revision. So I see both, member and current working rev in the project sbx.
    Any idea how can be achieved?
    I tried this:
       si print --recurse --filter=changed:sync --revision=:working
    But did not worked, command still shows the member revision only.
    Thanks, Regards,
    Jorge
    kthierer12-AmethystAnswer
    Regards
      Jürgen
