removing last commit from history?
hello,
I'm using souce integrity 2009 build 4.10.0.9049 SP 006/01
I started working on an existing project and as Robert (uncle Bob) Martin suggests I first checked out the code reformatted it and checked back in.
Unfortunately all the other developers are quite unhappy with that approach.
My changes are associated to a ChangePackage, but I commited to main line.
is there a way to remove my commit from the server?
bye
Thomas
    Hello Thomas,
    You can't remove a revision from the history (that would defeat the point of having a member history), but you can check in a new revision that is actually the revision just before the one you checked in, based on this article.
    Please let us know if that helps.
    Kael
    I cannot access that article, the login page says that my account (my email-address) is not known. Don't you have single sign on?
    bye
    Thomas
    That's odd, since the article is public.  Could you please contact PTC Support to have this investigated?
    Kael
