SNA to TCP/Ip conversion
Has anyone had to convert from SNA to TCP/IP?
Trying to find documentation to accomplish this task.
John
    David_GAnswer
    John:
    Sorry for the late reply to this ... but a transition from SNA to TCP should be pretty easy.
    • Configure your remote host system with the necessary hostname/IP & port information on panel 4 of the network configuration.
    • Change the remote environment to use TCP/IP-FTP as the distribution method on panel 3 of the environment config.
    • On the remote system, start the remote communication daemon process using the ICOMCTL command with the same port you specified on the remote system network configuration.
    Make sure any firewalls between the host & remote systems allows FTP traffic and the specified port.
    At this point, promotions to the remote environment will go over TCP/IP instead of SNA.
    Obviously, you can contact Implementer support if you run into any problems.
    David
    Hello John,
    I'm guessing you are specifically asking about Implementer, since Integrity Lifecycle Manager does not run over SNA. Is that correct?
    Kael
    David_G5-Regular MemberAnswer
    John:
    David
