Jan 9, 2017 5:20 AM UTC
What is the best approach to deploy solution on another system? Like if we have created some fields, types etc on one system how to take them to different system in a efficient way ?
    Jan 17, 2017 4:15 PM UTC
    Kapil,
    I am the PTC Integrity administrator for 2 separate servers.  We are using PTC Integrity LCM 10.9 running on Red Hat Enterprise Linux.
    When I need to create a large amount fields, triggers, queries, etc, I use the CLI.  You need to test those scripts first, because as you may already know the command line is unforgiving.
    To shorten the scripts I use variables.  The variables in the scripts are between the % %
    Example:
    REM - Variables
    SET HOST=--hostname=ptc
    SET CFIELD=createfield
    SET CMKS_DOMAIN_GRP=createmksdomaingroup
    SET EMKS_DOMAIN_GRP=editmksdomaingroup
    SET CPROJECT=createproject
    SET CQUERY=createquery
    SET CREPORT=createreport
    SET CSTATE=createstate
    SET CTRIGGER=createtrigger
    SET EPROJECT=editproject
    SET ETRIGGER=edittrigger
    SET USR=--user=ptcadmin
    Here is an example of a script that loops and creates 9 date fields with the names "Date Completed 01, Date Completed 02,Date Completed 03, etc." :
    FOR /L %X in (1, 1, 9) DO (im %CFIELD% %HOST% --type=date --description="Date Completed 0%X" --displayName="Date Completed 0%X" --name="Date Completed 0%X")
    or
    you could do this:
    im %CFIELD% %HOST% --type=date --description="Date Completed 01" --displayName="Date Completed 01" --name="Date Completed 01"
    im %CFIELD% %HOST% --type=date --description="Date Completed 02" --displayName="Date Completed 02" --name="Date Completed 02"
    im %CFIELD% %HOST% --type=date --description="Date Completed 03" --displayName="Date Completed 03" --name="Date Completed 03"
    im %CFIELD% %HOST% --type=date --description="Date Completed 04" --displayName="Date Completed 04" --name="Date Completed 04"
    im %CFIELD% %HOST% --type=date --description="Date Completed 05" --displayName="Date Completed 05" --name="Date Completed 05"
    im %CFIELD% %HOST% --type=date --description="Date Completed 06" --displayName="Date Completed 06" --name="Date Completed 06"
    im %CFIELD% %HOST% --type=date --description="Date Completed 07" --displayName="Date Completed 07" --name="Date Completed 07"
    im %CFIELD% %HOST% --type=date --description="Date Completed 08" --displayName="Date Completed 08" --name="Date Completed 08"
    im %CFIELD% %HOST% --type=date --description="Date Completed 09" --displayName="Date Completed 09" --name="Date Completed 09"
    Hope that helps you in some way.
    Dan
    kjain-21-VisitorAuthor
    Jan 18, 2017 4:37 AM UTC
    Yes i am using this approach that you explained (CLI) but i want to discover some other way to do this if we can .
    By the way a very much thanks to you for explaining my issue in such a better way.
    Jan 18, 2017 8:58 PM UTC
    Hi Kapil,
    Alternatively, you may want to reach out to your PTC account manager, and inquire about some services/solutions engagement work, as this is something they do and have some tools to create a solution to help facilitate what you're looking for.
    May 6, 2017 3:07 PM UTC
    Hi Kapil,
    the best and most efficient way to transport configuration changes is by using the "Integrity Stage Mechanism". This is build in, very convenient and exactly what you are looking for.
    This requires that both systems (e.g. PROD and TEST) are connected and then you use a wizard to transport admin changes accross.
    If you dont have a stage and do not plan for, then there is a consulting tool available that can help
    https://github.com/PTC-ALM/TIF‌
    This tool can extract and load from one into another environment. It is based on XML data representations. A documentation is included.
    Hope this helps
    Volker
    May 8, 2017 4:02 AM UTC
    Hi Volker,
    Thanks for your response and providing this valuable information. Appreciate your knowledge.
    Can you tell me more about this like how to use that consulting tool to pass data from one system to another without pairing (Staging) both systems. ?
    Regards
    Kapil Jain
    Jun 14, 2018 6:12 AM UTC
    this is the only thread that mentions the TIF Workbench. Therefore, I decided to publish attached tutorial here. I have not deployed a complete solution with this tool, however, I have generated scripts consisting of CLI commands that reflect differences of two Integrity solutions. These CLI commands might be used for migration between independent servers. Good luck!
    Best regards, Richard.
    Jun 15, 2018 6:54 AM UTC
    Hi @rheininger,
    Thanks for sending article in such a detailed way, I appreciate the way you documented it. Once again Thanks a lot. 🙂
    Kapil
