Composite laminate Export to .nas/.iges
  • November 20, 2025
  • 183 views
I am using Creo Parametric Release 12.4 and Datecode12.4.1.0
Hello, I use Creo Parametric and the composite module. We want to export the laminate defined in Creo Composite to .nas, and we can have two types of export: (.nas + .iges) or .h5. Neither of these two solutions allows us to output a .nas in IGS with the correct properties directly integrated. Is there a way to link the .nas properties with a step or IGS? Furthermore, the exported mesh is very poor; are there parameters that exist to improve it? Thank you in advance.
Community Moderator
November 26, 2025
Hi @JD_11596802
Welcome to the PTC Community!
Thank you for your question.
Your post has not received any response yet. I’d like to recommend to bring more details and context to your initial inquiry.
It also helps to have screenshot(s) to better understand what you are trying to do in your process.
Best Regards,
Vivek N
Community Moderation Team
