Constraining a Screw in a Slot in Creo 9
- 4 replies
- 3636 views
- Translate All
Hello dear colleagues,
I wonder if you guys could help me out with this constraint in Creo Parametric 9. I designed this slot feature and I have this screw that I want to place there and have 2 degrees of freedom, one translation back and forward in the slot and another rotation around the screw axis.
What types of constraint should I use? I tried Pin and Cylinder but I could not make that work.
Thank you so much for the help!
