Create Scale note for each view
Hi
In my drawing i have place 3 types of view with different different scales and I deleted the default scale note but now i need to create a new scale note for each views again. Suggest me with a best way to create that note again easily.
Ramaniedharan R
tbraxton
There are some parameters for scale available in drawing mode. This is for a detailed view "A" with a scale of 4
The syntax of the note shown above will look like this in a text editor.
{0:&view_name}(&det_scale)
In general use this:
The drawing parameter scale_of_view_x evaluates the drawing scale of whichever view has name X.
For example, to call out the scale of a view named DETAILED_BAR, type &scale_of_view_detailed_bar.
kdirth
Change view back to Default scale for sheet and apply, then change the scale back to the desired Custom scale.
Emeritus
Hello @RR_10572109,
It looks like you have some responses from some community members. If any of these replies helped you solve your question please mark the appropriate reply as the Accepted Solution.
Community Moderation Team.
