May 9, 2024 8:57 AM UTC
Creo 9.0 Options greyed out in "Mechanism"
- 5 replies
- 2426 views
- Translate All
I'm trying to create a spring in "Mechanism". What I did was I created two simple components in an assembly, and when the assembly is activated, I clicked Applications->Mechanism, and then a couple of options including "spring" are greyed out. in "insert" ribbon, only "servo motors" is available to select. All items in "properties and conditions" ribbon are greyed out. There is no "spring" option under mechanism tree.
I'm using Creo 9.0 Parametric. Can someone help?
Thanks!
