Dimension line size in inspection mode
  • August 3, 2024
  • 2 replies
  • 2829 views
When I add an inspection circle to some dimensions, the dimension line extends more than required. In the following figure, this condition is shown, could anyone help me adjust it (PTC Creo 2)?
Best answer by Radovan_DT
Figured it out its "dim_text_gap", your settings have 5, I am using 1
Community Moderator
August 8, 2024
Hello @MohaSharifi
Thank you for your question.
Vivek N
Community Moderation Team.
Hi Vivek,
Thank you
Chris3
I am not able to reproduce that in Creo 9. Is it possible to share a simplified model with the issue?
Hi Chris,
I attached the drawing and drawing option settings. I wanted to have all units in mm in the drawing option and changed most of them but I don't know which option controls dimension line length in inspection mode.
