May 1, 2025 3:10 PM UTC
Export Bend Center Line, Angle of Bend and Radius
I am using Creo Parametric Release 7.0 and Datecode7.0.9.0
We are working on an integration between Creo and a nest engine for our Fabrication area. Questions:
Can Creo export information like Bend center line, angle of a bend and radius?
Can it do it through the PRT file output as a property or variable?
If not, how can it be made possible?
We need this information for the nest engine to be able to create a bending program when it receives a flat from Creo. Creo would handle the unfolding process of the 3D model.
May 1, 2025 5:35 PM UTC
Article - "How to export bend information such as bend radius and bend angle using TOOLKIT in Creo Parametric": https://www.ptc.com/en/support/article/CS128619
Mahesh_Sharma
22-Sapphire I
May 8, 2025 3:39 AM UTC
Hi @PV_13385778 ,
I wanted to follow up with you on your post Post to see if your question has been answered.
If so, please mark the appropriate reply as the Accepted Solution for the benefit of other members who may have the same question.
Of course, if you have more to share on your issue, please let the Community know so that we can continue to support.
