Exporting CL Data for Grbl
  • June 8, 2017
  • 9 replies
  • 8020 views
I am seeking assistance in configuring Creo to export CNC code compatible
with the Grbl language.  I have attached two documents which define the
machine specifications and a summary of the Grbl language.
This effort will facilitate the lesson creation for Mechanical Engineering students
to export solid model geometry to a small CNC machine.
Any assistance with this effort will be very appreciated.'
Thanks for your help!
   Bill Chambers
Additional links:
   1)  Configuring Grbl v0.9 · grbl/grbl Wiki · GitHub
   2)  G Code Overview
Do you have the Creo NC module? If not, then you may make a drawing and export a DXF and use a DXF to G-code utility. This looks like a reasonable explanation Secrets of Going From CAD, Image, DXF, or STL to GCode for CNC and 3D Printing - CNCCookbook CNCCookbook
Hi William,
Do you have the possibility to create a manufacturing model ?
File -> New -> Manufacturing (it is an manufacturing assembly in witch you will assemble your part).
If yes we will be able to describe the process to get a gcode file from your machining operations.
If no, dschenken's answer is one of the possibilities but (for me) limited to 2d shapes : could be enough and faster for engraving or 2d machining.
Waiting your answer to get further ...
PS: you've attached 2 file extracts: what is the name of the complete document ?
I'm using bCNC and GRBL with gcode from CREO.
The first question is the same : Do you have the possibility to create a manufacturing model ?
If yes, the process could be described from machining operation to gcode output.
I use UNCXO1.P11 post processor and 90% of the code is understood by bCNC.
What kind of information are you waiting for ?
meprof5-Regular MemberAuthor
I am using Creo to create a Manufacturing model to generate surface milling tool paths
which are animated on the screen.  I want to export the resulting tool paths (CL Data)
to a desktop milling machine that is controlled with the Grbl language.
I am seeking assistance with configuring GPOST to export the Grbl compatible NC
code.
Any assistance with this effort will be greatly appreciated.
   Bill Chambers
  1. Configure gpost directory by setting gpostpp_dir in configuration editor - eg. C:\PTC\gpost
  2. Extract to this directory attached files - this is postprocessor compatible with grbl / bCNC (supports also circular motions)
  3. Export manufacturing operation to CL
  4. Post a CL file using UNCX01.P01 from PP LIST
Thank you for uploading this post processor.
I am a Mechanical Engineering Student here in Australia and I have designed and built a small 3 Axis CNC Machine.
I followed your instructions and the post-processor is working perfectly with my GRBL software, Arduino controller and Universal G Code Sender setup.
I can't thank you enough!
Dan
3-Newcomer
May 11, 2026
Has anyone in 2026 figured out a solution to this? Daniel’s pp is no longer available to download. I use UGS/gsender and a GRBL based machine. I have managed to make code work by asking chatGPT to replace the unrecognized commands, but that is not a viable solution.
