Framework AFX - Creating a new profile (Creo Parametric 9.0.2.0)
- 7 replies
- 2890 views
- Translate All
I have been trying to follow some previous discussions on creating a tube profile, but haven't had any luck:
Following the instructions, I have copied the customization folder to a network drive, however I noticed that the customization folder did not contain the three sub directories (*see attached) as mentioned in the instructions--they were separate. I tried dropping them into the Custom folder on my local copy.
After making a copy I tried two things:
1.)making a new folder directory and then copying and editing an existing profile
2.) adding a size to an existing profile
neither has worked.
I have mapped the customization folder in the afx options with no luck. I have also tried mapping the library path as well with no luck.
I have mostly copied and pasted the table text, but made sure to separate the table values with tabs. I am using notepad. I have also tried updating the sel_list with no luck.
What am I missing?
Thanks for your help!
