6-Contributor
Jul 12, 2024 6:29 AM UTC
Hole table through datum points need help on how to sort feature name column in re. order (Creo 10).
- 3 replies
- 1771 views
- Translate All
I am creating a hole table through datum points like feature name "POINT" & its "X,Y,Z" measurement through cs_o but when datum points go beyond 9 for e.g. "PNT9" then it sort by again first digit means it will go like 1 then 10,11,2,3,4 likewise (refer snap for more details).
I have tried to increase decimal point from 1 but it won't get sort out.
Need help to how to sort this double digit figures in ascending order & Is there any way to make this hole table parametric if point location is updating it will directly show on table without adding it again.
Hoping for the solution from PTC! 🤞
Application :- Creo 10 Paramertic
