18-Opal
December 1, 2016
How do you drive a Creo Parametric Part (.prt) parameters/attributes from file using a text file? Pro Program? Something else?
  • December 1, 2016
  • 7 replies
  • 13238 views
We have a parameter/attribute driven .prt template that we want to use to create new models based off a text file.
I looked at Pro/Program to do this but couldn’t find a Parameter/Attribute section.  I don’t think it would be a problem if the above were buried in the Pro-Program text file and it just replace the entire file, but I cannot even find which section this would go in.
E.g.  To use a simple example, let’s say we have a cylinder with 2 parameters, which drive the dimensions:
1) Diameter “Dia1”
2) Length “L1”
We then have relations that drive these 2 parameters that look something like this:
1) d1=dia1
2) d2=L1
We would like to have a text file that contains actual dimensions for “dia1” and “L1” to be able to create a model based off the above template and the contents of the text file such as:
Dia1=0.25”
L1=2.00”
Can Pro/Program be used for this?  Is there another way?  Is there a better way?  How can this be done?
I've only ever done this using trail files or mapkeys to modify existing part. I usually use VBA/Excel to generate the files. Pro/Program doesn't do this though some sort of Excel analysis might.
What is the workflow you expect to use if you had an ideal situation?
LawrenceS18-OpalAuthor
18-Opal
December 1, 2016
Expected use is:
User exports a text file containing driving parameters generated from a 3rd party program.
Mapkey to create the part from a template after the user references that part file with the driving parameters.
So the part of interest is a spring and we want to create the model based off of the spring design software output.
Hi Lawrence,
Your focus is "We have a parameter / attribute driven .prt template that we want to use to create new models based off a text file."
There are many ways to enter part parameter values and drive the part, but a simple way is from the relation.
Your idea is to go from a text file => Pro/Program => Part (* .prt), maybe change the workflow process to a text file =>Relation=> Part (* .prt).
Show an example as below,hope it helps you.
My English is pretty limited, please don't mind.
KC
yes, you can use Pro/PROGRAM.
Pro/PROGRAM example:
VERSION 2.0
REVNUM 86
LISTING FOR PART PRT0001
INPUT
VYSKA NUMBER
END INPUT
RELATIONS
D3=VYSKA
END RELATIONS
... and so on ...
When you regenerate a part, you use Read File command and enter file name (unfortunatelly you cannot browse folders...).
Example of myfile.txt contents
VYSKA=123
MH
We use Automation Gateway as well to handle parameters in models. It is easy to use, but it is not for free.
Hi  Gold ,
I think I can help you on this because that's the thing I am currently doing for my company.
Use Excel VBA and Mapkey in Creo, see example below:
Sub writeParameters()
Dim filePath, filePath1 As String, textData As String, fileNo As Integer
Dim FromPath, ToPath As String
Dim dataP01, dataP02, dataP03, dataP04, dsgDate, Ldate As String
Dim FSO As Object
Dim wbCnfgr As Workbook
      filePath = "full path and name of the text file which you write parameters to"   (Eg, "C:\AutoDesign\AutoDsg_D\A999-2740\03 CADFiles\15-X\xxx.txt")
     dataP01 = Range("A1")+ "=" +Range("B1")      '(A1=parameter name ,   B1= parameter value on your worksheet)
     dataP02 = Range("A2")+ "=" +Range("B2")
     dataP03 = Range("A3")+ "=" +Range("B3")
     dataP04 = Range("A4")+ "=" +Range("B4")
  Ldate = Date
  dsgDate = "/*Designed by ...on " + Ldate
fileNo = FreeFile 'Get first free file number
Open filePath For Append As #fileNo
Print #fileNo, dsgDate
Print #fileNo, dataP01
Print #fileNo, dataP02
Print #fileNo, dataP03
Print #fileNo, dataP04
Close #fileNo
'End If
End Sub
And in Creo you just create a makey to import the text file to your relation.
Two thoughts.  First, we have done something similar in the past to what KC Ai‌ is suggesting.  We created a bunch of feature parameters inside a stable (but never looked) in feature (one of the datum planes at the top of the model tree.)  We then created a mapkey to automatically browse to a folder and wait for us to pick a file, and then copy the contents of the file into this feature as feature relations.  Relations were added to the other features in the model so they referenced these feature parameters.  It was easy enough to build an Excel file that could directly generate the exact relations statements needed (we would copy them to a text file before importing.)
A second idea might be to use Nitro-CELL.  There is a free version available.  Definitely worth taking a look at.
HamsterNL
18-Opal
January 6, 2017
Here's the method we have been using for the past 10 years:
Microsoft Excel drives our 3D models. Basicly its a combination of the solutions by Martin Hanak (CREO side) and Changxing Lin (EXCEL side)
EXCEL
1) Create an Excel spreadsheet to calculate the values of the parameters which drive your part/assembly. Make the Excel spreadsheet as fancy as you like.
2) Use one sheet of that Excel spreadsheet to hold all the parameters (name of parameter in column A, value in column B)
3) Create an (ActiveX) button and write a small Excel VBA macro which will export all the parameters and their values to a text-file.
We use the exact same text-file over and over again, overwriting the contents when we generate something new. For example: "c:\temp\my_creo_parameters.txt"
CREO
1) Use INPUT parameters
Each PART and ASSEMBLY are driven by INPUT parameters. You can use STRING, YES_NO and NUMBER.
2) Use EXECUTE statements
Use the EXECUTE statement in your assembly to drive the INPUT parameters of any PART and/or sub ASSEMBLY
3) Use Mapkeys
As soon as a part or assembly contains INPUT parameters, you will get the option to use "Read file" when regenerating that part/assembly. Create a mapkey that will do "Edit" --> "Regenerate"--> "Read File" --> "c:\temp\my_creo_parameters.txt". You can also assign a mapkey to a button.
FINAL WORKFLOW
1) Open the Excel spreadsheet, configure your design, hit the button in Excel to generate the "my_creo_parameters.txt"
2) Open your design (part/assemby) in CREO, hit the button which executes the mapkey to read the values from "my_creo_parameters.txt"
P.s. If you are wondering how many parameters you can use...our biggest model uses 1264 input parameters at top-level.
HTH
HamsterNL
18-Opal
January 6, 2017
See attachment for an example.
Although not as detailed an answer as some of the previous ones, please take a look into External Analysis.  I have used it in the past to successfully read in customers' pre-existing algorithms/calculation results.  I usually modify the program to produce repeatable output (csv works well), then read the results into a part/assembly, pulling out whatever its needed. The results are fairly easily accessed from the analysis feature.  Depending on your needs, the analysis feature can exist anywhere in the model tree where you can hopefully avoid multiple regenerations.
You could also use an external program like Model Processor (free Guest version). It has an action to solve specfically this topic. http://mp.inneo.com , register , download , use. (only >= WF 4, better >= Creo 2.0) this shouldn't be seen as advertising so the guest mode is free and should solve the task.
Br,
Eike
