Yogesh.T
Feb 6, 2026 2:46 PM UTC
How to pick variable NOTES: while uploading Format to a drawing
We have three variations of Notes:
1.Generic
2.Harness
3.Fabrication and Assembly
How to let system give me option to use what I want on drawing in NOTES: ?
SEE IMAGE
Catalina
Community Moderator
Feb 13, 2026 2:07 PM UTC
Hi @Yogesh.T
Thank you for your question.
Best regards,
Catalina | PTC Community Moderator
Chris3
Feb 13, 2026 3:53 PM UTC
We do this with a mapkey that calls different notes, not with the format. There is an import text from file option that can be used with a mapkey.
Yogesh.T
Yogesh.T14-AlexandriteAuthor
Feb 16, 2026 11:45 AM UTC
Can you make a test case example? It might be golden for others to use and PTC to learn and grow. Thanks!
Someone gave me idea of using SYMBOL with variables. I am going to try that soon and post the outcome.
Yogesh
Chris3
Feb 18, 2026 3:48 PM UTC
An example really depends on what you want to do. Ours is quite complicated because it detects the drawing size and then launches an external app that allows users to pick notes before importing them on the drawing. The foundation for this is explained here:
https://community.ptc.com/sejnu66972/attachments/sejnu66972/customization/13797/1/VG-4052%20Dynamic%20Mapkeys%20to%20Automate%20Creo%202024-01-23.pdf
If you just want to import a text file then all you need to do is turn on mapkey recording while performing the clicks and then the mapkey will automate those same clicks the next time you run it.
In the drawing, on the annotation tab -> annotation group -> Note drop down -> Unattached note -> Absolute CSYS -> in the format tab -> Note from File
Emeritus
Feb 20, 2026 4:53 AM UTC
Hello @Yogesh.T,
It looks like you have a response from some community members. If any of these replies helped you solve your question please mark the reply as the Accepted Solution.
Vivek N.
Community Moderation Team.
