How to write ⏚ in a table or note?
  • August 29, 2019
  • 7 replies
  • 6068 views
I am making a table for drawings and need to use "⏚" (electric ground) in this.
I am unable to find it anywhere in Creo and if I try to copy/paste it I just get at square (□). Weirdly enough if I copy/paste this square to a text editor I get the ⏚ symbol again...
I now I can insert a symbol like this into the drawing but not into the table or a note.
It seems like the fonts in Creo does not support this standard unicode U+23AD symbol which is weird to me.
I am using Creo 4.0 M30
tbraxton
This may be font related. Make sure you have a font available in Windows font directory that supports the unicode character set and use that font inside Creo when creating the note.
Dale_Rosema
I have had things where if I type directly into the cell, it doesn't work, but if I right click and go to properties, I can then add it. Things changed when the went to WYSIWYG (what you see is what you get) typing.
mholst1-VisitorAuthor
So it seems the issue is simply that the standard fonts in Creo does not have the symbol.
This may solve similar issues for me in the future as I often have drawings with these squares comming from countries that use special alphabets e.g. Cyrillic.
Seems I was a little too quick to accept this as solution.
I have copied the font to the font directory and I can use the font in Creo. However on my drawing the symbol still shows up as a square...
In the Editor however it is show correct...
what font is set on Text Style tab in Note properties dialog box ?
