Piping material file
When using piping, you can select a material file in LineStock. When I select different materials, nothing happens to the pipe solids. When I change the Weight/Length, the weight of the pipe solids change.
When I change piping_material_source to material_dir, again, nothing changes.
Just want the pipes to get the right weight and appearance.
Is this yet another Creo option that doesn't work or am I missing something?
Using Creo 10
Emeritus
Hi @Matthijs1,
Thank you for your question.
Your post has not yet received any response. I am replying to raise awareness. Hopefully, another community member will be able to help.
Also, feel free to add any additional information you think might be relevant. It sometimes helps to have screenshots to better understand what you are trying to do.
Vivek N
Community Moderation Team.
