Tolerance text height the same as dimension text height in 3D annotation
- 4 replies
- 2673 views
- Translate All
When I created 3D dimensional marking in the Annotate module, the tolerance text height was the same as dimension text height. Usually, the tolerance text height factor should be 0.6, which means the tolerance text height is 0.6 times of dimension text height. I have set tolerance_standard from "ansi" to "iso", but the tolerance text height was still unchanged. Is there anyone knows how to change the tolerance text height in 3D annotate? Your help will be much appreciated!
