WF4 ModelCheck Problem
  • February 10, 2010
  • 8 replies
  • 4753 views
Hello Pro/E Users
I am having problems with Wildfire 4 M060 to get ModelCheck to load the configuration files from another location. I always get the error "ModelCHECK - Unable to determine loadpt directory.
ModelCHECK is disabled." when running ModelCheck. I tried setting the following:
1.In proe1.psf file - ENV=MCDIR=D:\rle\engineer\modchk\text\usascii
2. In proe1.bat - SET MCDIR=D:\rle\engineer\modchk\text\usascii
3. In user environment variable - MCDIR=D:\rle\engineer\modchk\text\usascii
Note: I copied the entire entire ..\engineer\modchk directory including all subdirectories to D:\rle\engineer\modchk
Does anyone know what can be causing this problem?
Best Regards
David Rodriguez
David,
here we have only copied the modchk config directory to our company setup
location and set mcdir to point to it in a batch file, but not in the psf
file.
/Bjarne
David Rodriguez <->
10-02-2010 16:49
Please respond to
David Rodriguez <->
To
cc
Subject
[proecad] - WF4 ModelCheck Problem
Hello Pro/E Users
following:
1. In proe1.psf file - ENV=MCDIR=D:\rle\engineer\modchk\text\usascii
Best Regards
David Rodriguez
Site Links: View post online View mailing list online Send new post
via email Manage your subscription Use of this email content is
governed by the terms of service at:
Hello Pro/E users
Thanks for your feedback and support on this issue. I was able to solve the problem by deleting all the modelcheck directories that I copied over to the new location and then just actually copying those directories under the "config" folder which actually contained the files which were different.
It looks like if you copy too many folders or all the modelcheck folders then Pro/E cannot find the ModelCheck loadpoint.
Best Regards
David Rodriguez
Hello All,
I am new to Creo ModelCHECK  and facing similar issue, I have created new MCDIR and created my own Config files and placed in my MCDIR, but I could not able to load the config options as. Can anyone please help me? Appreciate your help..Also please guide me if any tutorials are available.
Naidu
DomenicLaritz
Have you set the following config.pro setting:
modelcheck_enabled yes
And according to PTC's article CS57367 ("How to configure ModelCHECK in Creo Parametric") the usage of the environment variable MCDIR was supported until Pro/ENGINEER Wildfire 4.0 M090.
Since Pro/ENGINEER Wildfire 4.0 M100 you should use following config.pro setting modelcheck_dir instead of the environment variable MCDIR.
