11-Garnet
Feb 5, 2026 6:16 AM UTC
how to reduce the bom balloon size less than 0
I am working on a project where I want the size of the balloons to be reduced to less than the text size or close to the text size. I tried the min_balloon_radius and max_balloon_radius options, but they only allow increasing the balloon size because the minimum value for the balloon radius can only go down to 0, which is the same as the text size. However, I want to reduce the size to less than 0.
Is there any option available to reduce the size of the BOM balloon that 0?
Emeritus
Feb 12, 2026 11:10 AM UTC
Hi @RP_10384451,
Thank you for your question.
Your post has not yet received any response. I am replying to raise awareness. Hopefully, another community member will be able to help.
Also, feel free to add any additional information you think might be relevant. It sometimes helps to have screenshots to better understand what you are trying to do.
Best Regards,
Vivek N
Community Moderation Team
Feb 12, 2026 4:04 PM UTC
Have you considered using a custom balloon?
Chris3
Feb 12, 2026 6:31 PM UTC
7-Bedrock
Jul 30, 2026 11:01 AM UTC
Silly way: select all balloons and edit the font size. Hope there is a better way from other people.
