11-Garnet
Feb 14, 2025 9:58 AM UTC
parameter model name
Hi
I wold like to have parameter whit part name.
But not only name also  whit .prt  or .asm  at the end.
If i made whit relations  model_name=rel_model_name i get only name.
example  model name : Plate.prt   parameter -Plate
i would like to have
model name : Plate.prt    parameter -Plate.prt
How can i do that.
Van_AG
Feb 14, 2025 10:46 AM UTC
In the part template write down the relation
MODEL_NAME=rel_model_name+".prt"
In the assembly template
MODEL_NAME=rel_model_name+".asm"
Emeritus
Feb 20, 2025 10:05 AM UTC
Hello @TP_10167633,
It looks like you have a response from a community member. If it helped you solve your question please mark the reply as the Accepted Solution.
Vivek N.
Community Moderation Team.
Mar 27, 2025 6:35 PM UTC
I you are using Windchill, these parameters are automatic. Look in the parameter table.
Writing the relations is the way to go if no Windchill.
