Sep 26, 2025 5:44 PM UTC
Creo View Navigation
Hello
I noticed that when navigating through the model, you change what you're looking at by moving the model itself instead of your perspective. Meaning: the camera is fixed, and the only thing that moves is the model.
I'm looking for a way to navigate through the model (while using a spacemouse) in such a way that the model stays still, and the only thing that's moving is the camera. Think of it like the model is a building, and I'm changing what I see by flying a drone to see what I want. I've been able to approximate the functionality I'm looking for, but what throws me off the most is that the center of camera rotation is always around an object instead of around the perspective of the camera itself.
I'm using Creo View 10.1 with a SpaceMouse
I've tried changing my navigation mode to Catia and PTC Creo
I've tried changing my view mode from orthographic to perspective
I've tried both 3D navigation methods "as defined by the general model" and "explore"
I've tried inertial spinning turned off and on.
Emeritus
Oct 3, 2025 11:32 AM UTC
Hi @ZzCAD,
Thank you for your question.
Your post has not yet received any response. I am replying to raise awareness. Hopefully, another community member will be able to help.
Also, feel free to add any additional information you think might be relevant. It sometimes helps to have screenshots to better understand what you are trying to do.
Best Regards,
Vivek N
Community Moderation Team
