The difference between the create view adapter and the dilute adapter in the windchill
Hello to all
Windchill is working on it using Creo illustrate. Previously, I was using Creo View Adapter to convert illustrater data without any problems.
However, I found that it is an illustrater adapter.
The document says that it converts illustrater data with this, but I don't know a separate difference.
As a result, what is the difference between the Creo View adapter and the Illustrater adapter? I was wondering why the Illustrater adapter has a separate installation file.
Emeritus
Hi @SP_10210577,
Thank you for your question.
Vivek N
Community Moderation Team.
