6-Contributor
illustrate is published as a CGM diagram, and the CGM diagram is garbled in Chinese after the PDF is published through PE
illustra publishes the CGM diagram, and the CGM diagram is garbled in Chinese after the PDF is released through PE;
Subject - illustra发布成CGM图,通过PE发布PDF后CGM图中中文乱码
Body - illustra发布成CGM图,通过PE发布PDF后CGM图中中文乱码;
- By Community Moderation Team
Emeritus
Hi aaaaaaaaa,
Thank you for your question.
I’d like to recommend to bring more details to your initial inquiry. Also, It sometimes helps to have screenshots to better understand what you are trying to do.
Vivek N
Community Moderation Team.
