Center of Gravity in Drawings
  • March 14, 2012
  • 2 replies
  • 37088 views
Considering that the position of the CoG can be calculated using the mass properties function, is there a way that the CoG can be shown in a 2D drawing and be dynamically updated as changes are made to the part/assembly?
I know I could display the CoG csys and then manually lay a symbol over the top but I'd like this to be automatic.
Analysis --> mass properties
Click on the Preview button.
Ensure that the Feature Option is selected at the bottom.
The following pictures should explain.
Having done this, you may choose to have a POINT at this COG which would update dynamically at every REGEN.
How do you turn on the CSYS_COG or PNT_COG as they are greyed out?
I can create the feature as you state above but the resultant feature has no tangible properties to which I can attach a drawing symbol. In fact I can't find where the feature sits within the model as it does not create any visible reference when it is highlighted in the model tree.
Same question as asked here: http://communities.ptc.com/message/174277#174277
Hi
I have tried to create a part as suggested by Srinivasan Sir
I have created the feature and tried to use this in creating a csys
Note-These parameters are feature parameters
Check the following
I have created a csys with some random x,y,z offset value
Then i tried to control these offset values with relation
I have also attached the sample part for your reference
I hope this will help you
K.Mahanta
Dear All,
may i know syntax for retriving the weight or CG indivudual values to drawing and the family table( is it possible in family table?)
hari
Hi
You have asked for 2 things
1.Weight-
a)You can use system parameter pro_mp_mass to make your user parameter and use it in drawing, or family table
b)You can make a feature parameter in mass properties just like xcog,ycog ang zcog stated above; and then use this feature parameter to make your user parameter and use it in drawing, or family table
2.COG
You can use the feature parameters xcog,ycog ang zcog to make your user parameterand use it in drawing, or family table
K.Mahanta
Hi Mahanta,
may i know does it work on WF-3?
Hari
