3-Newcomer
Defining sling for lifting load analysis in creo simulate
Hello All,
 I am checking the carrying capacity of I section beam. I have applied 3000kg of load downwards divided equally into 8 bottom lugs. Two top lugs are tied to sling/rope leading towards a single point. I have created beams in creo simulate 7.0 to replicate the ropes using two end points - one on lug and one on top at a certain height..
see attached pictures for your reference
However after running simulation I am observing a high point load on lug where the beam starts. This seems to be something unusual. I believe the load should spread on the hole of lifting lug. Can you please advise if you have any suggestion to improve the definition of sling/rope in creo simulate? is there any better way to perform it? I would highly appreciate your help with it.
skunks
I would simplify the FEM model (example).
skunks
example:
Hello @skunks
Great example. I am trying to replicate a similar study for which I set up my model like you have suggested above. However, there seems to be something that I am missing or not doing correct as I am seeing funny results. If you could please check my model to see if you can find any missing pieces?
Kind regards,
Yash
Emeritus
Hello @HV_11420821,
It looks like you have some responses from  a community member. If it helped you solve your question please mark the appropriate reply as the Accepted Solution.
Vivek N.
Community Moderation Team.
