Planes and Axis' not visible.
  • January 16, 2015
  • 5 replies
  • 23968 views
I'm having problems with the display of Planes and Axis controls in Creo 2.0
When starting up the software I get the following Warning Error Message.
Upon trying to create an Axis on a revolved surface, the Axis line is not visible. This makes of adding a hole a pain.
In the filters, you can see I have the Axis and Planes active in the shortcut menu, but the options are grayed out and not selectable.
Sorry for wrong terminologies, I'm just transitioning over from SolidWorks to Cero.
Best answer by Mahesh_Sharma
Steven,
For a quick test, run Creo without any config.sup and check it out.
Steven,
check layers. If they contains axes and are set as hidden then you have to unihide them.
Martin Hanak
StephenW
Martin may be correct about layers but your screenshot of what's turned on and off is showing something.
The drop down list you are showing is the quick tool bar add list. Axis is checked to show an icon for the toggling the axis display on and off. If it's checked, you see the icon, if it is not check, you don't see the icon (for axis). It is not controlling the display of axis, it is control the toolbar. You access the toolbar controls using a right mouse button click. You toggle the icon using a left mouse button pick.
The axis icon in the toolbar is dimmed, signifying that the display of axis on the screen is still turned off.
Hi Stephen,
This is what I was trying to point out. Even though I have added them to the toolbar. They still appear to be off, or in this case "Dimmed" out.
I'll try again tomorrow, to see if there is a problem with the layers.
Mahesh_Sharma
22-Sapphire I
January 19, 2015
Steven,
Mahesh_Sharma
22-Sapphire I
January 16, 2015
Steven,
As Doug mentioned one of the possible reason for axis is option display_axes no in config.sup.
Regarding warning on start "Feature obtained" is to inform that the license for Routed_System_set is obtained by Creo and that is correct as this license is not for Creo. You can edit your *.psf file in <Install Location>\parametric\bin and remove Routed_System_set. Warning will not prompt after removing this license from PSF.
Hi Mahesh, there is no option in the .psf file to remove the Routed_System_set.
// PTC - PSF file: parametric
PRODUCT=Creo Parametric
DESC=Creo Parametric (default)
SHIPCODE=M110
CREO_COMMON_FILES=Common Files\M110
ENV=MECH_LP=%PRO_DIRECTORY%\mech
ENV=MECH_HOME=%MECH_LP%\%PRO_MACHINE_TYPE%
ENV=PRO_MECH_COMMAND="%CREOAPP_DIRECTORY%\bin\parametric.exe" "%CREOAPP_DIRECTORY%\bin\parametric.psf"
ENV=RPC_TIMEOUT=31536000
ENV=MEDI_HOME=%MECH_HOME%
ENV=PATH+=%PRO_DIRECTORY%\%PRO_MACHINE_TYPE%\deflib
ENV=PATH-=%PRO_DIRECTORY%\%PRO_MACHINE_TYPE%\lib
ENV=PATH-=%INTRALINK_DIR%\%PRO_MACHINE_TYPE%\illib
ENV=PATH+=%PRO_DIRECTORY%\libs\dfor\lib
ENV=NMSD_TIMEOUT=300
ENV=PRO_COMM_MSG_EXE=%PRO_DIRECTORY%\%PRO_MACHINE_TYPE%\obj\pro_comm_msg.exe
ENV=PROE_START=%CREOAPP_DIRECTORY%\bin\parametric.exe
ENV=CDRS_DATA=%PRO_DIRECTORY%
ENV=PRO_IMAGE_CONVERTER=%PRO_DIRECTORY%\%PRO_MACHINE_TYPE%\obj\convert_image.exe
ENV=PROGUIDE_DIRECTORY=%PRO_DIRECTORY%\uifdoc
ENV=SPG_DIRECTORY=%PRO_DIRECTORY%
ENV=PRO_USRMAIN=%PRO_DIRECTORY%\usrprog\umain\usrmain.c
ENV=PROTABLE_DIRECTORY=%PRO_DIRECTORY%\protable
ENV=MOZILLA_FIVE_HOME=%PRO_DIRECTORY%\%PRO_MACHINE_TYPE%\obj\MOZILLA
ENV=PROTAB=%PRO_DIRECTORY%\%PRO_MACHINE_TYPE%\obj\protab.exe
ENV=ZIP_EXEC=%PRO_DIRECTORY%\%PRO_MACHINE_TYPE%\obj\zip.exe
ENV=CLHOME=%PRO_DIRECTORY%\text\pcldata
ENV=PVIEW_PROEPVIEW_HOME=%PRO_DIRECTORY%\apps\prodview
ENV=CV_ENV_HOME=%PRO_DIRECTORY%\%PRO_MACHINE_TYPE%\CV140
ENV=DEBUG_HLP_DLL_PATH=%PRO_DIRECTORY%\%PRO_MACHINE_TYPE%\lib\dbghelp.dll
ENV=PTC_D_LICENSE_FILE-=********
ENV=CREO_APP=PMA
ENV=CREOPMA_FEATURE_NAME=PROE_Foundation PROE_FoundationAdv (*** ** *** ***4 *****)
RUN="%MECH_LP%\install\nt\pro_mech_env.bat"
RUN="%PRO_DIRECTORY%\%PRO_MACHINE_TYPE%\nms\nmsd.exe" -noservice -timeout %NMSD_TIMEOUT% &
RUN="%PRO_DIRECTORY%\%PRO_MACHINE_TYPE%\obj\xtop.exe"
// USER - PSF
// Add User specific environment or run applications below here
ENV=DBG_NCPOST_PATH=%CREOAPP_DIRECTORY%\bin
ENV=PRO_ALLOW_EARLY_RETURN=TRUE
Steven,
Routed_System_set is represented by numerical code 10105 inside the brackets on ENV=CREOPMA_FEATURE_NAME line. Simply delete this code.
Martin Hanak
Hi folks,
I managed to get it working now. It appears that by removing the following from the config.sup file resolves the issues I was having.
display_planes yes
display_plane_tags yes
display_points yes
display_point_tags no
display_axes yes
display_axis_tags no
display_coord_sys yes
display_coord_sys_tags yes
Thanks all for your help.
