3-Newcomer
Feb 17, 2026 12:55 PM UTC
Radial (Centrifugal) Fan in Creo Flow Analysis
I am using creo flow analysis (creo 11.0.4) with the base license.
I would like to simulate a free standing centrifugal (radial) fan in a simple air channel.
How do I simulate that?
I can create a fluid volume and at the locus of the fan I create a circular interface. I can now choose "fan" for that interface and add a local function as a dp-curve. So far so good. However, creo considers that fan automatically as axial fan and, therefore, the fluid flows straight through this interface. I could add swirl (radial and tangential velocity) to the fan, but I have to add these values in m/s (and I don't know these). Furthermore, I can not select the rotation direction. I saw that alternatively I could choose "rotating wall" as boundary condition if I have a solid that represents the fan blades but I could not manage to create a fan with that. I am also not interested in the flow right through/in the fan but rather through the whole channel. What is the difference between "rotating wall (boundary condition)" and "fan (interface)"?
Many thanks for the help.
Philip
Do I need a plus or premium license to simulate a
Emeritus
Feb 23, 2026 10:01 AM UTC
Hi @PC_10446540,
Thank you for your question.
Your post has not yet received any response. I am replying to raise awareness. Hopefully, another community member will be able to help.
Also, feel free to add any additional information you think might be relevant. It sometimes helps to have screenshots to better understand what you are trying to do.
Best Regards,
Vivek N
Community Moderation Team
Feb 24, 2026 6:39 PM UTC
Hi!
A good resource for the setup of any simulation with rotating components would be the Mixing Tank tutorial be found in the Creo Online Help Center: https://support.ptc.com/help/creo/creo_pma/r11.0/usascii/index.html#page/tutorials_pma/Mixing_Tank_Overview.html#wwID0EFJEV
The Fan condition you'd found other Interfaces is great for system level modelling where the fan can be replaced with a simpler fan curve calculation saving on simulation complexity and time.
Modelling rotating or translating geometry does require the Moving/Sliding mesh capability found in the Plus package.
Emeritus
Feb 25, 2026 3:24 AM UTC
Hello @PC_10446540,
It looks like you have a response from a community expert. If it helped you solve your question please mark the reply as the Accepted Solution.
Vivek N.
Community Moderation Team.
