Jun 27, 2024 10:22 PM UTC
y+, intelligent wall formulation, BL questions about Creo Flow
I'm starting to play around more with Creo Flow and am a little unclear about the available options for modeling the boundary layer
1) Is there an option to select a laminar boundary layer or is everything just modeled using a turbulent BL with k-eps formulation?
2) Are there other turbulent BL options other than k-eps?
3) does the k-eps BL option include an intelligent wall formulation, where the cells in the BL that have a y+ lower than some cutoff value are ignored?
4) What are some of the levers that I can pull to achieve y+ values in the typically desired range of 13-31?
Thanks!
MArk
cfdgeekAnswer
Aug 24, 2024 12:55 AM UTC
Hi
yes, in the physics module, just add flow without turbulence, then you don't have turbulence models in the project.
yes, we have k-e and also RNG and realizable k-e, but k-e should fit be a good fit for most of cases.
Yes. we already consider y+ range and turbulence BL structure in our wall functions. e.g. log low and sub layers
You can try reduce the surface mesh size and also consider reduce the aspect ratio of the mesh. all those meshing controls can be found in mesher properties.
Hope this helps!
Community Moderator
Jul 4, 2024 6:58 PM UTC
Hi @MW_10424792,
Thank you for your question.
Also, feel free to add any additional information you think might be relevant. It sometimes helps to have screenshots to better understand what you are trying to do.
Anurag
Jul 8, 2024 2:24 PM UTC
Many thanks for your help!
cfdgeek13-AquamarineAnswer
Hi
Hope this helps!
Aug 26, 2024 7:08 PM UTC
Thanks – that’s very helpful!
Mark L. Whittum, P.E.
Senior Principal Mechanical Engineer
O: +1 978.490.2240
C: +1 617.501.0341
mark.whittum@collins.com
Raytheon | An RTX Business
Global ISR Sensors & Software, EO&IR Solutions, Advanced Products and Solutions
7 Technology Park Drive
Westford, MA 01886
rtx/raytheon.com | LinkedIn | Twitter | Instagram | Facebook | YouTube
Emeritus
Aug 29, 2024 3:27 AM UTC
Hello @MW_10424792,
It looks like you have a response from a community member. If it helped to answer your question please mark the reply as the Accepted Solution.
Vivek N.
Community Moderation Team.
Sep 24, 2024 1:55 PM UTC
Very helpful - thanks a bunch!
Mark
