Oct 16, 2015 12:41 PM UTC
Family table creating from existing family table
I am looking at creating a new family table of a part from one of our existing family tables. I have tried to save a copy of the generic and hoped the instances would go along for the ride, but to no avail.
Can someone provide step by step how to take an existing family table to create a new family table?
Thanks in advance.
TomU
Oct 16, 2015 2:14 PM UTC
Saving a copy of the generic normally brings the family table with it.  You will need to open the model and rename the instances before they will appear in the File/Open dialog...
Oct 16, 2015 2:25 PM UTC
open the model and rename...
I am confused.
When is this step done? Before or after the attempt to save the family table.
BTW I am running Creo 2.0 M160 with Windchill.
Can I save a copy of the family table within Windchill easier than within Creo?
TomU
Oct 16, 2015 6:25 PM UTC
Just to refresh my memory, I did some testing.  Here is a summary:
Stand-alone Creo - Disconnected from Windchill
Save a copy on the generic only
    • New generic is created.
    • Family table is preserved.
    • New instances keep their original names. ***
*** This means instances from both generics cannot be open or in session at the same time. ***
Save a copy of a single instance
    • Only the instance is copied
    • New stand-alone part is created (no family table).
Connected to Windchill
Save a copy of the generic only - from Creo
    • Not allowed due to instance name conflicts
Save a copy of the generic only - from a workspace
    • Only the instance is copied.
Save a copy of the generic and some (or all) instances - from a workspace
    • New generic and related instances created.
    • Family table kept intact for all selected instances.
Save a copy of a single instance only - from a workspace
Generic set to "New Object"
      • By default, Windchill wants to create a new generic with a family table of only this one instance
      • End result, one new generic and one new instance, both completely unrelated to the original objects.
Generic set to "Reuse"
      • New instance is immediately added to existing Generic (without checking out or revising the generic)
      • This new instance is now part of the original family table, even though the generic was never actually modified.
Windchill - From Commonspace
Save As of a single instance only
      • This new instance is now part of the original family table, even though the original generic was never actually modified.
      • There doesn’t appear to be any way to delete this new instance without checking out the generic and removing it manually from the family table.
May 11, 2016 10:28 AM UTC
This Works for me
Open Generisk from Workspace
<Save As> – <Save a Backup>
Choose local disc
Close file and erase Memory
Choose “No Server”
Open Generic in Creo
Manage File – Rename
Open the Familie Table
Rename all the Instance in the table
Verify and then Save
Go Online
Open Generic from Disc
Save
