How to remove Intralink parameters in Creo models
  • September 19, 2021
  • 10 replies
  • 2901 views
Sometimes you need to clean up CAD data before sharing it with a third party or you would like to update Start parts templates and remove old PDM parameters.
You need to Set config.pro options:
dm_emulate_ilink_sys_parameters=yes
allow_create_pdm_param=yes
This is great! I can update our company start part/assembly, but why do I have to be offline?  I need to be able to checkout the start files from our Windchill, remove the dead intralink parameters and then check back in.
*edit*  Nevermind, I made the changes offline, then reapplied the server and added them to the workspace they were checked out in to check-in the modified versions.
Hi, thanks for your note.
If I need to update start files that are stored in Windchill, I use the process that I download files to local hard drive and then I remove parameters.
After update start files - I will update data in Windchill.
Your process of using Offline mode is also good 😉
Thanks again and have a nice day.
3-Newcomer
February 11, 2026
We have Creo10.
I can't find both options in the configuration editor:
  • :dm_emulate_ilink_sys_parameters=yes
  • allow_create_pdm_param=yes
Are those hidden in Creo10?
Chris3
Replying to HW_9999718
Yes they are hidden. Put them into your config.pro and then launch Creo and you should be able to modify the parameters
3-Newcomer
February 11, 2026
Replying to Chris3
When I try to add these options, I can't click on OK (it's not activated/still grey)2026-02-11 13_03_40-Creo Parametric Options.jpg
Chris3
Close Creo, add them to your local config.pro and then restart.
3-Newcomer
February 11, 2026
Replying to Chris3
They are now in the config.pro but I still can't remove the Intralink parameters (they are still locked).2026-02-11 13_41_38-Parameters.jpg2026-02-11 13_39_00-Creo Parametric.jpg2026-02-11 13_38_40-Creo Parametric.jpg
Chris3
You have to get out of a linked session.
File -> Manage Session -> Server Management -> NO SERVER
Then try
3-Newcomer
February 11, 2026
Chris3
Its been a while since I have done this. Try backing it up to a local (ie C: ) drive; verify that you are not in a linked session and then open it from the local drive and see if you can make the change. If that doesn't work try all of these steps:
https://community.ptc.com/t5/System-Administration/Removing-locked-parameters/td-p/1034139
PTC article on this:
https://www.ptc.com/en/support/article/CS105842
