Designating Parameters for FeatureIDs in Assemblies via Web.Link
Hi everyone,
I'm currently working with PTC Creo Web.Link and trying to determine whether it's possible to designate a parameter specifically associated with a FeatureID within an assembly context.
I've reviewed the Web.Link documentation and found the method pfcScript.pwlParameterDesignationAdd(), which seems to apply only to general model parameters. However, I haven't found any reference to designating parameters that are tied directly to a FeatureID.
Has anyone successfully designated a parameter linked to a specific feature within an assembly using Web.Link? If so, could you share any insights, approaches, or code examples?
Any guidance would be greatly appreciated!
Thanks in advance!
RPN
18-Opal
November 3, 2025
We do this for find numbers on assembly component feature. But I have no clue which one will win if you would use the same name twice. I mean TEST as a designated solid and a feature parameter. I hope Creo will raise an error.
Community Moderator
November 11, 2025
Hello @JV_14385993,
It looks like you have a response from a community member. If it helped you solve your question please mark the reply as the Accepted Solution.
Vivek N.
Community Moderation Team.
