Jul 10, 2024 12:19 AM UTC
Enable Simscape Multibody Link Creo-Pro/E Plug-In
I'm trying to follow the directions, from:
https://www.mathworks.com/help/smlink/ref/linking-and-unlinking-simmechanics-link-software-with-proengineer.html
So I can access the toolkit and simulate my assembly in Simulink, but I can't seem to find the protk.dat file the website mentions.
I looked in the configuration files that PTC Creo is running and the protk.dat file wasn't there either. I attached a screenshot below.
How should I go about this?
Jul 10, 2024 7:56 AM UTC
https://www.mathworks.com/help/smlink/ref/linking-and-unlinking-simmechanics-link-software-with-proengineer.html page tells you that you have to create protk.dat.
Open Notepad and put into it something like this:
name Simscape Multibody Link
startup dll
exec_file matlabroot\bin\os\cl_proe2sm.dll
text_dir matlabroot\toolbox\physmod\smlink\cad_systems\proe\text
unicode_encoding false
end
Then save the file as protk.dat. Please check that file file name is really protk.dat (prevent the creation of protk.dat.txt file).
Community Moderator
Jul 17, 2024 3:25 AM UTC
Hello @LH_11210795,
It looks like you have a response from a community member. If it helped to answer your question please mark the reply as the Accepted Solution.
Vivek N.
Community Moderation Team.
