Kepware 6.15.154
I have installed Kepware 6.15.154 while installation I have not asked about username and password.After installation when  click on Setting it asking for password. What is default admin password.Also it was not connecting to thingworx.
ntripathiAnswer
Greeting @KG_96
I hope you're doing well!
I would like to inform you that to reset the administrator password in KEPServerEX follow step 11 in the below document (KEPServerEX installation guide).
If you don't want to set the administrator password check the box "Skip setting a password at this time."
Take a look:
KG_9610-MarbleAuthor
I have try this one but while installation i does not seen any username and password window.
ntripathi16-PearlAnswer
Greeting @KG_96
Emeritus
Hello @KG_96,
It looks like you have some responses from some community members. If any of these replies helped you solve your question please mark the appropriate reply as the Accepted Solution.
Community Moderation Team.
This problem has been solved with the help of Kepware Team.
Thank You...
