Dec 2, 2025 1:40 PM UTC
TCP G43.4
Are any users familiar with using G43.4 to program 4 axis Horizontal Milling Centers utilizing simultaneous 4 axis motion?  If so, can you explain the basics of how you got it to work for you?
Thank you,
Matt
bmullerAnswer
Dec 10, 2025 4:14 PM UTC
The biggest change G43.4 (Tool centerpoint control)  will make to your programming is that you are no longer limited on where the machine coordinate system must be located in relation to your part location. Without TCP, you *must* set your machine coordinate system on the rotation axis of your 4th axis. In addition, without TCP, the machined accuracy of the part is directly correlated with how accurately the part is located in relation to the true machine centerline.
Disclaimer: I don't have a machine with this feature. I have researched it with future use in mind.
Here is a good video explaining it. Although made by Mastercam, the principle should be the same in Creo.
https://www.youtube.com/watch?v=1gaEeUEVElw
Catalina
Community Manager
Dec 5, 2025 3:32 PM UTC
Hi @razmosis
Thank you for your question.
It appears that your post has not yet received any response. I am replying to raise awareness. Hopefully, another community member will be able to help.
Best regards,
Catalina | PTC Community Manager
bmuller14-AlexandriteAnswer
Emeritus
Dec 16, 2025 8:32 AM UTC
Hello @razmosis,
It looks like you have a response from a community expert. If it helped you solve your question please mark the reply as the Accepted Solution.
Vivek N.
Community Moderation Team.
