May 20, 2025 7:01 AM UTC
i file di fabbricazione non si aprono dopo l'installazione
I am using Creo Parametric Release 2.0 and DatecodeM040
abbiamo spostato correttamente creo m040 dal vecchio pc al nuovo, ma la parte CAM non funziona. non apre nemmeno il file di fabbricazione.
    Emeritus
    May 27, 2025 7:05 AM UTC
    Hello @AC_10041462,
    Thank you for using PTC Community.
    Your question has not received a response so far.
    In order to receive meaningful responses from other community members, could you please provide more details and context regarding your inquiry? Specifically:
    1. Can you confirm if the installation process completed without errors? What is the operating system on your new PC?
    2. Are you seeing any specific error codes or messages when trying to open the CAM files?
    3. Did you transfer the Creo configuration files and licensing properly from the old PC? Were there any changes in settings?
    4. Could you please add some screenshot(s)?
    This will enhance the likelihood of receiving valuable assistance from other Community members.
    You might also find it useful to refer to this informative video on how to ask a good question.
    I hope this information is helpful.
    Best Regards,
    Vivek N
    Community Moderation Team.
