Feb 12, 2026 4:11 PM UTC
Creating a Itune deployment for MathCAD Prime 11
Hello Everyone,
I am trying to create a deployment in Intune for MathCAD prime 11 that uses the xml configuration files as a reference, but so far, I have been unsuccessful.
I was wondering if anyone has success with deploying MathCAD prime via Microsoft Intune? If so, may I ask, what command line did you use? or possibly PowerShell script if that is what you use?
Feb 12, 2026 5:34 PM UTC
Not specific to InTune, but we had to set an environment variable PIM_LOG_ENV to a temp folder to get the Mathcad Prime 10 silent install to work properly (install is running as SYSTEM via SCCM).
See Article - CS332340 - Mathcad Prime installer fails to install with status unsuccessful on specific machines immediately after start
and
Article - CS160244 - Is a third party software a supported method to deploy the silent installation of Creo Parametric and Mathcad Prime
Other than the modification listed above, the setup.exe -xml <filename.xml> method worked fine.
Dan N.
Feb 13, 2026 9:52 AM UTC
Article - "Is a third party software a supported method to deploy the silent installation of Creo Parametric and Mathcad Prime": https://www.ptc.com/en/support/article/CS160244
Resolution
Emeritus
Feb 19, 2026 12:28 PM UTC
Hello @VD_9564715,
It looks like you have some responses from some community members. If any of these replies helped you solve your question please mark the appropriate reply as the Accepted Solution.
Vivek N.
Community Moderation Team.
