An alternative to MATHCAD 15.
  • November 7, 2024
  • 19 replies
  • 5203 views
Since it is no longer possible to install MATHCAD 15 on  my new PC, even though I have a perpetual license, I am looking for a software that is up to its standard. I was offered MAPLE FOLW...What do you think?
Best answer by ppal_255687
If you try these steps, then maybe you will have some success - or you can post specific questions as they arise. Hope it works.
Step 1: Download and Install VirtualBox
  1. Go to the VirtualBox Website: Visit https://www.virtualbox.org.
  2. Download VirtualBox:
    • Click on "Downloads".
    • Choose the version suitable for your operating system (Windows, macOS, Linux, etc.) and download the installer.
  3. Run the Installer:
    • Open the downloaded file and follow the installation prompts.
    • Accept the license agreement and configure the installation settings (default settings are usually fine).
    • Click "Install" and, if prompted, grant permission for the installation.
  4. Complete the Installation:
    • Once the installation is complete, click "Finish".
    • Launch VirtualBox to ensure it has been installed correctly.
Step 2: Install Mathcad 15
  1. Insert Mathcad 15 Installation Media:
    • If you have a physical installation CD, insert it into your drive. If you have a digital copy, extract the installer files to a location on your PC.
  2. Run the Installer:
    • Locate and double-click the setup.exe file to start the installation.
  3. Follow Installation Prompts:
    • Accept the license agreement.
    • Choose your desired installation folder and follow the on-screen instructions.
    • Complete the installation and restart your computer if prompted.
Step 3: Emulate a Physical Address for Mathcad 15 License
Mathcad 15 licensing sometimes ties to the physical (MAC) address of a network card. To emulate or spoof this address on a different PC, follow these steps:
Step 3.1: Find the Original MAC Address
  1. Get the MAC Address from the Original PC:
    • On the original PC where Mathcad 15 is licensed, open a Command Prompt.
    • Type ipconfig /all and press Enter.
    • Note the Physical Address of the network adapter (e.g., 00-14-22-01-23-45).
Step 3.2: Change the MAC Address on the New PC
  1. Open Device Manager:
    • Right-click the Start button and select Device Manager.
  2. Find the Network Adapter:
    • Expand the Network adapters section.
    • Right-click the adapter you want to modify and select Properties.
  3. Modify the MAC Address:
    • Go to the Advanced tab.
    • Find the Network Address or Locally Administered Address option.
    • Select it and input the original MAC address (without hyphens, e.g., 001422012345).
  4. Click OK:
    • Save the settings and close all windows.
    • Restart the computer if necessary to apply changes.
Note
  • Network Restrictions: Some systems may not allow direct MAC address changes depending on hardware or driver limitations.
  • Virtualization Note: When using VirtualBox, you may also have to configure the network adapter within the virtual machine to use the emulated MAC address.
  • Potential Issues: Be aware that emulating a MAC address may cause network conflicts if two devices have the same address on the same network.
This configuration should enable Mathcad 15 to recognize the licensed MAC address and function properly.
18-Opal
November 7, 2024
Well according to Maple Flow (Great!)
How Maple Flow Compares to Mathcad® - Maplesoft
According to this forum (??)
How Maple Flow Compares to Mathcad - PTC Community
I believe you can use MATHCAD 15 on new PC in case that you are allowed to install virtual machine with appropriate operating system and MATHCAD 15 installation inside this virtual machine.
-MFra-21-Topaz IIAuthor
